"digital table"
a digital control table from a digital waveform looks like this
__________0_______________________
0 0
29 1
50 0
30 1
how to extract the two columns from the digital control table into a 2d array ?
Message 1 of 8
(3,906 Views)
the 29, 50 and so on are the the index in which it occurs and the 1 and 0 are the digital values
Message 2 of 8
(3,897 Views)
Hello martian,
do you mean something like this?
Message 3 of 8
(3,888 Views)
yes !! thanks alot, but can i have the file instead of the screen capture, btw where did you get the get waveform attribute.... could not find a correct one ?
Thanks for the help !!!
Martian
Message 4 of 8
(3,876 Views)
i need the file in labview 7 format
its great to learn here
Message 5 of 8
(3,873 Views)
Hello martian,
you will find the "Get Waveform Components" in the Waveform palette, just the first in the upper left corner... It's polymorphic, so the "0101" in the icon will pop up, when you connect a digital waveform.
Message 6 of 8
(3,857 Views)
Hello martian,
I just found out, that there is a subfolder "digital waveform" in the waveform palette and there is a "get waveform components" too...
Message 7 of 8
(3,855 Views)
Thanks Gerdw for your help, help me save alot of time to figure that out
Message 8 of 8
(3,840 Views)
