"array in loop programming problem"
Hello!
In my attached file(which is a similar, analogous problem to my real program) I have three generated numbers in a while loop(lets say 11 loops).
I want to have a 1D array with these total 33 numbers.
first loop:
I want the first numbervalue on top to be the first in array. The second value in middle to be second. The last value to be third in array.
second loop:
The first value on top to be fourth in array. The second value in middle to be fifth. The last value to be sixth.
third loop:
etc.....
How do I program this? Cant make it work. Please help. See file.
Thanks Fredda
(2,957 Views)
This should do what you want. It's just an initialized shift register and another build array. With the build array, you want to select concantanate inputs.
(2,958 Views)
thanks!!
(2,953 Views)
