"append front panel image to report"
I am using the "append front panel image to report" and it works fine but when I build the application everything runs fine except the report is not generated.  I get no errors there is just no report.
(2,527 Views)
The standard response is that it should work.  I would guess that this is a bad path issue.  If you are using the VI path as your start path then it can change between development and deployment.  If it is a hard path then make sure all the folders exist before writing the data.  Send the path to a dialog using path to string to see the actual path that is is using.  Let me know if this helps.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,511 Views)
