"TDMS Close" error codes
Hi!
I would like to get a list of error codes which "TDMS Close" function can generate.
In general: it would be nice if this kind of list exists for ALL functions. Handling errors would be easier and applications could be more user friendly for the final user.
Ljubo.
(4,257 Views)
Ufff... I don't think you can get that from anywhere 😮
Epictetus
Antoine Chalons
(4,250 Views)
TDMS error code generally spans from -2500 to -2550, in LabVIEW, you can choose "Help" -> "Explain Error " to view all the error codes and the explanations.
(4,231 Views)
Oh well... maybe you can then Smiley Surprised
Epictetus
Antoine Chalons
(4,222 Views)
In fact you are usually able to get list of errors from certain group of functions. In LabVIEW help, search for error codes, and you should see list of groups for which you can get list of errors.
Example: Storage/DataPlugin and TDM Streaming Error Codes.
Marking solutions and kudoing messages can improve searching, if someone will need help on similar problem!
Stefo
(4,209 Views)
Thank you for your suggestions.
Ljubo.
(4,192 Views)
