"Serial Communication-Receive xxxx0Axxx¡±.
I used LabViews 6i. I modified example ¡°Serial Communication Examples--Serial Communication¡±.
I can not receive Hex xxxxxx0Axxxx correctly.
Please help,
Q. Han
Message 1 of 10
(3,335 Views)
What does it display and have you set the string indicator to Hex display instead of Normal?
Message 2 of 10
(3,335 Views)
the received message stoped at 0A, no more reading.
Hex 0A = /n
Message 3 of 10
(3,335 Views)
You need to change the termination character by using the serial configuration vi. By default it is set to hex 0A.
Brian
Message 4 of 10
(3,335 Views)
Thanks.
How can I change the configuration to "without termindation character". Because, all the data is usefull, and no one know what I should get before I get it.
Han
Message 5 of 10
(3,335 Views)
I usually wire a zero to it, and I've never had any messages truncated.
Brian
Message 7 of 10
(3,335 Views)
See if this helps:
In the sub-vi Serial Read with Timeout.vi, modify the Instr property node to
add the property Message Based Settings:Termination Character Enable. Wire
false to Term Char En. Or add Message Based Settings:Termination Character
and change the Term Char.
"qh01132" wrote in message
news:506500000005000000922D0000-991728092000@quiq.com...
> Hex 0A = /n
Message 6 of 10
(3,335 Views)
"add the property Message Based Settings:Termination Character Enable." is good solution.
Unforturnately, my labView (version 6.0) does not work, no matter whatever I write-- false or true.
I can change the Term Char. But I really need make "Termination Character Enable" work.
Message 8 of 10
(3,335 Views)
You also need to set "Serial End Mode for Reads" to 0 (End none); the
default is 2 (TermChar).
Not obvious, I agree.
Jean-Pierre Drolet
"qh01132" a écrit dans le message news:
5065000000050000008B2F0000-991728092000@quiq.com...
LabVIEW, C'est LabVIEW
Message 9 of 10
(3,335 Views)
Jean-Pierre,
Thanks. It works.
By the way. Is any good book for these 'Not obvious' secret.
Thanks again,
Han
Message 10 of 10
(3,335 Views)
