ā08-09-2016 07:49 AM
Are "Memory is full" and "Not enough memory to perform this operation" errors written to Windows event logs? And where exactly? I want to make task scheduler to restart LabView program if this errors will appear.
ā08-09-2016 08:33 AM
Why don't you track down the problem rather than trying to bandaid it? Do you have the source code?
ā08-09-2016 08:42 AM
This is quite big program, so maintaining problems needs a lot of time. We just need temporary solution, while searching for bugs.
ā08-09-2016 09:14 AM - edited ā08-09-2016 09:15 AM
I don't know if it gets logged or not but it would most likely be in the Application or the System group. If you do find it there, select the event log entry and click Attach Task to This Event....
This is Windows 7. Probably different in 10. MS had to go and change everything again....kinda like the NI forum layout.
