"Driver for AT-M10-16DE-10 Card for Windows 2000 Server"
THis Card (At-M10-16DE-10) is of technology ISA. I need the Driver for than works with Windows 2000 Professional
(2,642 Views)
if I got it right and you mean the AT-MIO-16-DE-10, than NI-DAQ 7.2 is the latest one for Windows 2000 Professional.
http://digital.ni.com/softlib.nsf/websearch/50F76C287F531AA786256E7500634BE3?opendocument&node=132070_US
If your subject is right, and you use windows 2000 Server, than it might work. It is not officially supported, but should be no problem.
One note, NI-DAQmx, the new DAQ Driver Architecture, will NOT support this Board. You are restricted to the older NI-DAQ driver as mentioned above.
Regards
Stephan A.
(2,642 Views)
