"Decorations" property of cluster = backwards?
LabVIEW 8.6.1f1
Create a cluster. Put an indicator in it to keep the compiler happy.
Put a box decoration in it.
Use a DECOS[] property to get references to decorations.
Use an INDEX ARRAY node with two outputs to separate deco references.
If you have one decoration in the cluster, it is #0 in the array, #1 is not-a-refnum.
That's understandable.
If you add another decoration to the cluster, the new one is #0 and the box is now #1
Why ?
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(2,900 Views)
Hi Steve,
it's the same in LabVIEW 8.5. You can see the same behavior for the "allElements" Array.
Mike
(2,875 Views)
Hi Steve,
this is because the new decoration is added on top of the other.
The order of decorations in the Decos[] array is the same of the Z drawing order.
You can alter this order using Move to Front etc..., so beware of this if you plan to change decorations properties by code!
Paolo
(2,869 Views)
