"Date/Time To Seconds" Function does not respond to "fractional second" input
The "Date/Time To Seconds" function (contained in the Function\Programming\Timing - Palette) does not respond to the "fractional second" input (see attached example).
Reimar Spohr
Message 1 of 8
(3,728 Views)
Accepted by topic author ReimarSpohr
Hi Reimar,
as I don't see your example I can only say: It works as expected:
Message 2 of 8
(3,725 Views)
I think he means if you go straight to a DBL type.
Tim
GHSP
Message 3 of 8
(3,711 Views)
Hi Tim,
there is only one "Date/Time to Seconds" function in the mentioned palette...
Can you explain "go straight to a DBL type"? I don't get the point.
Message 4 of 8
(3,706 Views)
User posted their code in a new thread. Smiley Mad
Let's keep the discussion here.
Message 5 of 8
(3,700 Views)
To poster:
I tried your example. Works fine. Are you trying to set the control to a value greater than or equal to 1?
From the documentation:
fractional second is the fractions of a second since the start of the second. Values must be greater than or equal to 0 and less than 1.
Message 6 of 8
(3,694 Views)
Why convert at all? You should be able to simply add the DBL value to the timestamp.
Jim Kring's "Thinking in G" blog has a nice example of relative time calculations.
http://thinkinging.com/2007/06/08/labview-tip-easy-relative-timestamp-calculations/
Message 7 of 8
(3,673 Views)
Are you trying to add fractional seconds to the existing time that includes fractional seconds?
Or are you trying to replace the existing time with a time that is a particular fractional second?
You are doing the latter.
Message 8 of 8
(3,654 Views)
