"Data cannot be exported. This feature is only supported by time continuous logs. Please use the convert to ASCII feature instead".
Hello Everyone,
I am new to Labview. I used it to log continuous Temperature and Voltage data. I have successfully exported the Voltage data to Excel, but for the Temperature it says "Data cannot be exported. This feature is only supported by time continuous logs. Please use the convert to ASCII feature instead". Will appreciate some help in handling this. Thanks
(2,310 Views)
Hello Almond,
What VI are you using to log the data? Also, how are you acquiring the data? Are you using the DAQ Assistant, or acquiring through DAQmx functions? Maybe it would be easier to see what's going on if you posted your code here.
Cheers!
TJ G
(2,286 Views)
