"AutoScale don't work correctly with the FP closed"
In order to print a graph, I've created a sub-vi which prints on
completion. I'm using an attribute nodo to autoscale the graph, but
I've seen the graph does not update when de Front Panel is closed. If
I open the panel and run it again then works correctly. What can I do
to get the automatic autoscale
(2,748 Views)
Can you post your VI here so that one of us may look into your problem.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,748 Views)
We've seen the problem of charts not being updated when the VI is minimized. The only workaround is to not minimize the VI if you need the image from a chart.
Do you have charts or graphs? Could you plese post a VI?
Zvezdana S.
(2,748 Views)
