question on amp hour battery capacity measuring
I am trying to measure a lithium ion two cell battery for amp hour capacity. I can get the value by running the battery down to the lowest recommended charge level and this gives me the amp hour value, but how do I calculate what the amp hour would be if I only discharge to 80%?
(3,111 Views)
I doubt that you will find an expert on Li battery discharge models here, Google may help 🙂
http://www.google.com.sg/search?sclient=psy&hl=en&source=hp&q=lithium+ion+capacity+cycles+modelling&...
-AK2DM
(3,080 Views)
Give this code I will modify and return to you.but convert this code in labview 8.5 and send to me on my email vplabade@rediffmail.com
(3,050 Views)
