question on DAQmx
is there a way I can get a string array output of all the DAXmx Global
Channel names in a given task? Kind of like GETNAMES?
Jim
http://www.effectivetest.com
(2,789 Views)
Jim,
DAQmx Task property node Channels returns the names of all virtual channels in the task.
Zvezdana S.
(2,789 Views)
Zvezdana S. wrote:
> Jim,
> Zvezdana S.
Yes but the return type is a channel type, not a string. How can I get
an array of string names for each DAQmx Global Channel in the task?
Jim
(2,789 Views)
Jim,
You can wire an array or strings indicator to the output of Channels property node.
Zvezdana S.
(2,789 Views)
