question about string constant in Hex display format
how to get a plus of 2 string constant which is display in Hex display like attahced, for example I have string "28" and "5D" in Labview which has been in Hex format, the plus of this 2 string should be "85" in Hex. pls help on this, thanks
Message 1 of 9
(4,081 Views)
Hi Neil Lan,
you can use the TypeCast function.
Mike
Message 2 of 9
(4,073 Views)
Hi Mike
I saw the result is "8500 0000" instead of the result "85", do you have any comment.?thanks
Message 3 of 9
(4,063 Views)
You probably have a 32bit number wired to the type cast type input. Use a U8 constant (will only work if the sum is <= 255).
Message 4 of 9
(4,049 Views)
This'll work, too.  I'm afraid of casting types... Smiley Surprised
Jm
Jim
Message 5 of 9
(4,038 Views)
You shouldn't be. After all, it uses less code, and requires less hoops to jump through.
Message 6 of 9
(4,034 Views)
thanks, I get it
Message 7 of 9
(4,026 Views)
Hi Jm,
it will not work, because the string in my example is as required in hex display. Smiley Wink
Mike
Message 8 of 9
(4,012 Views)
I think the confusion may lie in the fact that the OP said "Hex display" as well as "Hex format". Those who have used LabVIEW for a long time know these are 2 different things. However, those who have not used LabVIEW for a long time may take these to mean the same thing, and may interpret it one way, as opposed to the other. That is not incorrect, it's simply not making a distinction that they may not be aware of.
Message 9 of 9
(4,001 Views)
