question about exe application builder
Using LV6.1, I built an exe application. But after I fixed it on the other pc, the communication interface can't be selected, which made the application can not run.
Hope the helps. thanks very much.
(2,634 Views)
With LV versions earlier than 7.0, you need to install VISA separately, using the NI Device drivers CD
Paolo
(2,619 Views)
Hi xyl,
it seems a port is missing for your program... Or you didn't choose the right port...
But you didn't gave many informations on this problem Smiley Sad
(2,616 Views)
