question about empty template in MS word toolkit generation
@ben64 wrote:
@Bob_Schor wrote:
I should have noted that I ran my test on a Windows 10 x64 system, Office 2013 (64-bit), LabVIEW 2016 (32-bit).  I'll be "out" tomorrow, but if there's no resolution, I'll try on Wednesday to test on a Windows 7 x64, Office 2010, LabVIEW 2012/2014/2016 system.  I think I also have a LabVIEW 2011 VM (but I may have discarded it ...).
I tried LV2012, 2014 and 2015 with Office 2010 and the result is as expected (only 2 columns). Using Windows 7 pro
Ben64
I am using LV 2011 on word 2013, do you think it is a version issue?
Now on LabVIEW 10.0 on Win7
Message 11 of 19
(1,582 Views)
@aputman wrote:
Turns out, after doing a small amount of research, it is possible to add a chart to a Word document (using the code below) but the method for editing the dataset (in an Excel worksheet) is not available.  Are you required to use Word?  If not, I suggest to use Excel and the method above.  If Word is required, you can use the Excel method above, save a picture of the chart and load that into your Word document.
Can you please post in LV 2011 version? I can't find the InlineShapes property node.
Secondly, yes, I am limited to use WORD as I have to add other items to my report as well, graphs are just 1 part of the report
Message 12 of 19
(1,579 Views)
That VI is on the RGT pallete -> Word Specific -> Advanced -> Word Get ActiveX References.
This is not version specific.  I have LV2011 installed and I get the expected output with Word 2010.
aputman
Message 13 of 19
(1,569 Views)
you have Word 2010, I have word 2013
Message 14 of 19
(1,562 Views)
@LV_Enthu wrote:
Ben64
Those versions are not compatibile. See link below
http://digital.ni.com/public.nsf/allkb/C9408B9F08D711E786256F3300701D01
-Matt
Message 15 of 19
(1,551 Views)
Could be because according this Report Generation Toolkit Compatibility with Microsoft Office and LabVIEW http://digital.ni.com/public.nsf/allkb/C9408B9F08D711E786256F3300701D01
--LabVIEW (Report Generation Toolkit) 2010 supports Microsoft Office XP, 2003, 2007, 2010 and Not "2013"
uday
Message 16 of 19
(1,548 Views)
oh no!! that's a bummer... what could i do now?
Message 17 of 19
(1,545 Views)
Either downgrade MS Office or Upgrade LabVIEW to 2014 which supports Office 2013.
uday
Message 18 of 19
(1,542 Views)
Unfortunately, I can't do either of them, as almost all my work is done in LabVIEW 2011, and the company won't fund it.
Similarly, the policy is to use Office 2013
Message 19 of 19
(1,540 Views)
