question about PID
Hello
I'm using the PID VI (PID compatibility in Labview V6.i) in order to control
an experimental loop (try to control the gas flow rate in my experiment).
In all exemples that I could find in the LABVIEW help, it seems that the
output signal (in %) is an ''absolute'' signal, so that this value shouls
directly be sent to my valve which is controlling the gas flow rate.
Unfortunately, If I suppose that it is really the case (absolute signal), it
doesn't work.
On the contrary, If I consider that the output coming from the PID is a
relative corrective signal, it seems to better function.
does anyone know why ?
Sincerely yours
Fabrice
(2,799 Views)
A "pure" PID calculation (CmdCorrection(e)=P(e)+I(e)+D(e)) outputs a
pure "correction" value. Because of the integral term, the output
command will recursively converge to any value that makes the error sink
to 0, so it is not stupid to wire it as an absolute command value, with
no (ie. null) offset. In some case (!), it will converge.
But because of the recursive nature of that calculation, you have an
initialization problem. To function properly, your regulation needs to
start in a reasonable initial system state, including an appropriate
initial command value, which should cause a reasonable initial error. So
the total command calculation rather looks like:
Cmd=InitialCmd+CmdCorrection(e)
Do I get the point ?
(cea... Grenoble ?) - oz
Fab
rice François a écrit:
>Hello
>doesn't work.
>Sincerely yours
>Fabrice
(2,799 Views)
