query external program status
I have an application that requires an external program to be running in the background.  I can successfully open the program from within labview, but on a second pass I get an error message saying that the program is already running.  Does anyone know how I can query the status of that program (running or not) from within labview to avoid trying to open a running program
(3,640 Views)
Jerry_T,
I found a way using .NET.  I attached a VI that looks at the currently running processes to see if Notepad is running or not.  I think you could easily adapte this to find any application.  You can also search for a process by window title by using MainWindowTitle property.  Hope this helps.
-cb
(3,628 Views)
You didn't mention which operating system, so assuming Windows, and if you're on Windows XP Pro, you can use the "tasklist" command with the System Exec function:
You can easily parse the string to find the process you're looking for.
Message Edited by smercurio_fc on 10-24-2007 04:15 PM
(3,619 Views)
If I remember correctly I think on Linux it's "ps -ef | grep programname". Not sure - my Unix is a little rusty.
(3,614 Views)
10 Degree
Thanks!  With slight modification I was able to create a universal vi that looks for any running process.
(3,606 Views)
