quantifying absorbance in LabView from amplitude.
I am currently trying to develop a way to convert amplitude to absorbance, and to be honest I am not sure if this can be done using LabView.  Can this even be done?
(2,653 Views)
LabVIEW can do almost any math operation (spherical bessel functions, etc...).  So, as long as you can develop an algorythm that is: absorbance as a function of amplitude (Y = Absorbance(amplitude)) you will be fine.
I assume that amplitude is a acquired signals value.  Just work the algorythm, and then push the acquired data through your analysis routine before displaying on a graph, writing to a file, or whatever your use case is.
Let me know if you have any questions.
J
(2,650 Views)
Absorbance in optical instruments is based on the logarithm of the amplitude. One hundred percent transmission equals 0 absorbance. 10% transmission is absorbance = 1.0 (if I recall correctly). On most instruments absorbance ranges from 0 to 4 (0.01% T?). The resolution of your A/D converter will be the limiting factor at high absorbance unless you change the gain (and the corresponding scaling in the software).
Lynn
(2,642 Views)
