qtxml4.dll error
I am using LAbVIEW version 8.2. LabVIEW has been giving me errors about missing DLLs. The following files have been reported to be missing (one after the other i.e., LabVIEW reported the first file as missing. When it was downloaded from Internet and placed in system32 folder and LabVIEW was restarted it showed the same error for the second file and so on);
QtXml4.dll
mingwm10.dll
QtCore4.dll
After showing the error the LabVIEW ran fine.
Now that I have downloaded and copied the dlls in the system32 folder , LabVIEW complains about entry point not found in QtXml4.dll.
Yesterday I had installed Simple TCP Messaging (STM)  module. Could that be the culprit?
I can't even configure the perforce client as SCC in LAbVIEW as missing dll complaints are being reported by LabVIEW.
Any ideas?
(3,558 Views)
I don't normally go around downloading DLLs that I know nothing about, so I'm not sure why you did so. Smiley Surprised
Those DLLs seem to be from various sources. Among these are: Photoshop Elements, Lightscribe (burning of labels on CDs), and something called QT (not QuickTime). I assume the Simple TCP Messaging module that you're referring to is this one? I've never used that, and don't know anything about it. When did these DLL errors start? After you installed this module? Were you ever able to start LabVIEW without getting those DLL errors?
(3,536 Views)
