pyrometer acquisition date
Dear
I am Nicola PhD student , I bought a pyrometer Micro-Epsilon thermoMeter, the instrument give a output 0-5 V, it is able to measure the temperature between 100 -1000 C, I connect with the desktop by USB cable. My aim is determinate the temperature measure with Labview in real time.
I try to use the VISA to comunicate with the sensor, but always give a error -1073807339, and not show the current temperature.
someone can you help me?
contact n.fois@sheffield.ac.uk
Message 1 of 14
(4,651 Views)
Are you sure that the port configuration values are correct?  Is the error in the "error out intermediate" indicator?  If it's not, try increasing the timeout, or put a wait between your VISA send and receive, to give your device time to respond.
Jim
Message 2 of 14
(4,648 Views)
It would be helpful to name the type of sensor, provide a link to a datasheet (even better a link to the document for the communication)
Seems that the meter USB port is FTDI based and provide a serial port......
And the USB connection can't read the 0-5V analog voltage output 😉  but maybe the value is already in digital format 🙂
Greetings from Germany
Henrik
LV since v3.1
Message 3 of 14
(4,608 Views)
Can you post the VI with 2011 compatibility.
The error what you are getting is timeout error which means if you haven't connected to input timeout in VISA config then operation(i.e. write and read) expected to complete in 10s(default) but its not happening.
Post the VI, will deal with it.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 4 of 14
(4,605 Views)
Dear all, thanks for the fast answer
jcarmody :the configuration of the port I hope it is correct, because the software look like find something, the sensor.
Henrik_Volkers I attached the datasheet of the sensor, pp3 I have the one with range 150 -1000 C.
Ranjeet_Singh I change the timeout input, but still not working, i attached a screen shot of the block diagram, I think
is not possible to save in previous version,,
thanks
Nicola
Message 5 of 14
(4,589 Views)
One small change: The init serial needs to be outside the loop , and you should read all data , I attached a mod.
If you have a link to the protocoll more help is possible.
Henrik
LV since v3.1
Message 6 of 14
(4,574 Views)
Hi
thanks
now it not give error anymore.
In my case the sensor is direct connect with the laptop by USB, I hope, it is possible way with these sensor.
now from VISA read, i have an array output, how can I convert this volt/bit in temperature value, and also is it possible to plot the temperature against the time.
how do you suggest to do?
I also attach the catalogue of the sensor, about connect and output.
many thanks
Nicola
Message 7 of 14
(4,558 Views)
Sorry, but in the document you attached I found NO information about the protocol and data formats used. Why did you post it?
Post the data format 🙂
and as homework for the weekend: Do the LabVIEW tutorials 😄  Look at the examples about graphs and sharts!
Henrik
LV since v3.1
Message 8 of 14
(4,547 Views)
Hi
The data protocol , I do not know how find, what do you mean exactly.
I do not understand very well the read buffer, the read buffer should be the data obtain from the sensor, so the value of the temperature, then I convert in array bit value, then from bit I need to determinate the real value in temperature.
Also I do not understand why the value from the read buffer it`s always the same  when the temperature value read from the sensor change.
Do you think I need to convert the read buffer in another way?
Nicola
Message 9 of 14
(4,529 Views)
How about picking up the phone and ask the manufactor?
Spoiler
PHD student ??? But hopefully not a engineering PHD student.... SCNR
Henrik
LV since v3.1
Message 10 of 14
(4,511 Views)
