pxi_clk10 missing?
I'd like to use the PXI_Clk10 signal to synchronize dsa tasks, as per the shipping example Multi-Device-Sync-AI and AO-Shared Timebase & Trig-DSA.vi
The problem is, PXI_Clk10 isn't an available choice from the drop down list of terminals, although I can see it when I create a task in MAX.  Where is it?  How do I get it?  I'm using PXI-4461/4462 devices in a PXI-8196 controller.
Thanks for any help!
(3,229 Views)
Just a guess, but you can right click the name constant and select "I/O Name Filtering" to see other channels.  Maybe it is available in the Advanced Terminals.
Hope this helps,
Jon
(3,219 Views)
Thank you - that is exactly what is wrong!
(3,215 Views)
