pwm by fuzzy logic
how to make pwm by fuzzy logic, can help me ? because i have project which relate this.....
Message 1 of 8
(3,782 Views)
You have a very basic problem in what you want to do in that you are, in a sense, wanting to mix apples and oranges. PWM is a very precise process on the other hand, fuzzy logic is an imprecise statistical process.
Now having sad that you could use fuzzy logic to derive the value you want to transfer using PWM.
MIke,,,
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(3,774 Views)
I don't undrestand about your explain.... I want to control heater with fuzzy.
Message 3 of 8
(3,771 Views)
In that case you can use fuzzy logic to calculate the heater setpoint - but that is a separate question from how you want to transfer that setpoint to the heater. What you are wanting to do has really three steps:
  1. Read the current temp
  2. Calculate a new setpoint for the heater
  3. Sending that new setpoint to the heater.
A temperature controller simply does those three things over and over again. Note that step 2 can be pretty tricky while steps 1 and 3 are generally pretty easy.
Do you need drivers for generating PWM using a digital output?
Mike...
LabVIEW Champion
Message 4 of 8
(3,769 Views)
Yeah. I want to use step 2 and 3. Because output from fuzzy logic will use controlling the heater. I use the heater which voltage ac. Can you help me?
Message 5 of 8
(3,766 Views)
 Can you the project more information?
Message 6 of 8
(3,762 Views)
My project is water heater. I use fuzzy logic for control the heater.
I use heater which the voltage ac 220v. Many article I read for control the heater using pwm. I want to mix fuzzy logic with pwm. Output from fuzzy is used bntar the pwm. Can you help me.
Message 7 of 8
(3,757 Views)
To learn how to generate a pwm signal, do a search in the examples that ship with LV for "PWM".
There are several examples.
Mike...
LabVIEW Champion
Message 8 of 8
(3,749 Views)
