11-21-2008 01:40 PM - edited 11-21-2008 01:41 PM
i wanna put a triangular and a sinusoidal signal in a waveform. i've bundle (i don't know if this is the right thing to do) them but i'm getting wire problems.
can somebody help me?
p.s. - my VI is attached
11-21-2008 02:00 PM
Use the build array instead.
Note: If you go to the block diagram with Context Help turned on and move your mouse over the chart terminal, the help window will give you the correct data types (2D Mulitplot -1 or more pts. Also, a graph is usually used instead of chart.
11-21-2008 02:56 PM
Thank you 🙂
Now i have to, using a ring, make several operations with the signal: add, sub, divide, mult. and show the result of the chosen operation in a new wavechart.
I've just done this because i'm not understanding how does the ring constant works...
11-21-2008 03:23 PM
You probably want an enum rather than a ring. Use an enum to select a case. Each case contains a different operation. Put the whole thing in a while loop with an event structure.
As Dennis said earlier, a graph is probably more appropriate than a chart because your data is available as an array all at once. Charts are for data which comes in one point at a time.
Lynn
