put qmd 220 Mass spec labview program into my labview code
I have written one labview code which perform DAQ and solenoid valve control
Right now I hope I could combine 3-rd party Mass spec labview program with my programe
Becasue I need to use mass spec data  to trigger my process.
Run or stop or save data in Mass spec program is controlled by event structure
Do you have any advice?
I need to change a little for their mass spec program, right?
I try to use refnum...does not work
since it is based event structure in Mass spec code..
(2,899 Views)
I may use dynamic user event, right?
(2,896 Views)
Hello dragon-long,
Is the control you are looking to get based on the analyzed spectrometer data? You can create a boolean equation that sets a case structure to handle when the DAQ write tasks occur that control the solenoid in that case.
Ian M.
(2,875 Views)
Yes. It is based on analyzed spectro data
Case structure is good
Right now my problem is I try to conbine mass spec driver into my labview program.
Mass spec driver is controlled by  event structure
(2,853 Views)
The following is an example for generating a user event for an external signal which should help you move forward with your program.
https://decibel.ni.com/content/docs/DOC-12455
Ian M.
(2,836 Views)
Nice
I will take a look at it
(2,833 Views)
