push button labview program
hi every body
i need help in my attachement program
the question is to
Modify the logic so that the program is executed using the ‘RUN’ button only
in the beginning and then the STOP button from the program should be used
for flow control. This means that once the program has been started using
‘RUN’ button, the push button should be able to make the execution stop.
Now if the same push button is pressed again the program should resume
without having to use the ‘RUN’ button again.
please i need help
my labVIEW is 8.2 and i can't open 8.5
thank you very much
(6,300 Views)
The VI you posted is in 8.2.1 which you can open in 8.2.
As for the question ... seems awfully like a homework problem to me.  What exactly is your question?
(6,293 Views)
yes i can open this file it is the first part of my homework and the second part i can't solve it and i need help in it
(6,273 Views)
If you want help and not to be simply ignored (no one here is about to do your homework for you) please tell us what exactly you are having trouble with and what you have tried to do to solve the problem. I am sure we will be more than happy to help you by answering specific questions.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(6,270 Views)
i didinot say solve my homework
i just want some idea if you have
my question is how to make the same button act as start and stop
(6,236 Views)
By the 'run button' do you mean the white arrow at the top left?
If so, you cannot do what you are asking, as the push button will stop your program.
For getting a start and stop algorithm, I would suggest looking into an events structure.
Message Edited by yenknip on 03-03-2010 11:07 AM
_____________________________
- Cheers, Ed
(6,230 Views)
By "the same button" I'm assuming you're referring to the button that's currently on the front panel. Let's examine what you have. There are two different run conditions. The run button in the toolbar starts the overall VI. The VI executes whatever code is in the block diagram. If there's a loop then it continues to run the loop until the condition to stop the loop is met. Whatever is inside the loop runs each time the loop iterates. What's happening now? Well, each time the loop runs it:
  1. generates a random number,
  2. does some calculations,
  3. waits a set amount of time,
  4. and checks to see if the button's value is True.
The one button that's on there now is used to control whether the loop should stop. So, how would you control whether to perform steps 1-3?
I think that's a big enough hint for you, don't you? Smiley Wink
(6,203 Views)
