punctured viterbi decoding using Xilinx IP core for LAbview FPGA 2014
HI
I want to apply viterbi decoding to my 3/4 punctured stream using xilinx IP core for labview fpga.
I read that for punctured of viterbi decoder v.7, depuncturing has to be external. Is there a code for depuncturing available?
What is the purpose of erasure flag?
I have to first append zeros in places where punturing is done?
How should I set the rate? Is there a design example available for hard coded 3/4 punctured viterbi decoder. Constraint length 7. If so please share.
(2,917 Views)
Has anyone ever be successful in implementing Hard decoded viterbi decoding with depuncturing? All the posts I have read so far, nobody was able to implement it successfully.
Please share if you are able to run your depunctured code.
(2,667 Views)
