pulse width measurement
Is there anyone can give the help?
 Currently I'm doing the project to measure pusle width of a generator. The pulse width level HIGH = 100uSec and level LOW = 300uSec. It will generate 5 pulse and low for 8.3mS and continue 5 pulse and so on.
Now I'm use hardware M series Multifunction DAQ NI 6221, so how to use this hardware to capture the data pulse timing?
Thanks for your advise.
(2,929 Views)
If these pulses are TTL/CMOS compatable the easiest is to use a counter and look at the pulse width measurement examples.  If this is not a standard voltage or has varying pusle widths (not a pulse train/oscillator) then you can sample it using an analog collection (use sampling of 10+ times the durration of the smallest pulse) and there are waveform analysis functions to find just about any parameter of the waveform you might be interesten in,
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,915 Views)
