pulse generation on PC parallel port and its maximum frequency
Can i generate pulse pattern on any one out of 8 lines of IEEE1284 using Labview? if yes what is minimum period and duty cycle?
Yours sincerely
(2,465 Views)
Greetings, Ali;
While I have personally never done it, would you happen to have checked the Whitepaper on the subject? It contains a fair amount of information and might be of aid:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIM3CAO&l=en-US
I will look into the matter a tad more and let you know if I find out a bit more about this particular application.
Cordially;
Simon P.
(2,434 Views)
