publish two vi's
can i publish two different front panels using a remote panels.
thanks
(2,362 Views)
Yes you can. Create the htm files for both the VIs and then merge them into one. I'm not an expert on html so there may be a better way but I just took the section from the line that starts with "var obj" to the line that starts with "</OBJECT" and pasted it into the first file before the "</TD>" line and I got both VIs on the web page.
(2,348 Views)
