public malleable vi (calling a protected dynamic dispatch method) inconsistent behavior [bug]
LabVIEW 2020
I am seeing an inconsistent behavior with a public vim calling a dynamic dispatch protected member. The calls is not broken as long as no child is made or loaded into memory. Once a child has been made (and the override created) trying to reconnect the call to use the child brakes the wire (at that point I am unclear what is the desired behavior).
Note: Cross posted on LAVA
call is not broken (but converted vim is broken with a scope error).
Also, this code above just run fine (and the protected dynamic dispatch does as well).
everything seem fine (but converted vi is still broken)
code is broken and can not be "unbroken"
(2,263 Views)
