protection of vi by mac address
Hallo,
I am new to labview. I am trying to protect a VI by mac address so that it can be used on a single PC only. I searched for tutorials, but I got nothing. Is there any tutorial or example VI from where I can get some help.
Thank for your support.
Wenshu
Message 1 of 12
(3,358 Views)
Hi ,
read the MAC address using SysExec ("ipconfig /all"), then compare with a pre-defined number.
What exactly is your problem? Where are you stuck?
Message 2 of 12
(3,349 Views)
For example, consider any simple vi . How can i protect the VI with mac address of specific computer so that it runs only on specific PC. and when other PC tried to runs the same VI, it shows error or does not run on other PC. I am stuck how to do it because there is no tutorial regarding this.
Wenshu
Message 3 of 12
(3,300 Views)
Hi Wenshu,
despite changing your alias my answer from message #2 doesn't change.
Have you tried that?
Can you attach your approach in your VI? Where are you stuck?
(Btw. when you search the LabVIEW board for "read MAC address" you find a lot of related threads.)
Message 4 of 12
(3,298 Views)
If it is a a computer specific ID you are after and no specifically a mac address, you could also use generateComputerID.exe from <Program Files>\National Instruments\Shared\License Manager\Bin\ and run it with System Exec.vi.
Certified LabVIEW Architect
Message 5 of 12
(3,282 Views)
Yes, I just want to protect the vi so that it can run on only one computer and it can't be run on other PCs.
I will look at the example of generateComputerID.exe with System Exec.vi and will return to you. Thanks for the help.
Wenshu
Message 6 of 12
(3,273 Views)
Would this approach work on a MAC?
Message 7 of 12
(3,036 Views)
It would as long as you find similar commands on the Macintosh that will give a network adapter's MAC address.
Message 8 of 12
(3,024 Views)
Thanks you for the reply. This helps.
I am new to coding and LabVIEW. I wrote a program using approach (assuming that I would not have to worry about read MAC address based on OS) shown on this page:
How Can I Get The MAC Address From My RT Target?
What would be the drawbacks of using this approach?
It takes up to 2% of CPU usage
Message 9 of 12
(3,018 Views)
If it is continuously using 2% of your CPU, then you should reconsider your architecture. Why do you need to repeatedly check the MAC address?
Probably you can check it once at the beginning of your application, then either continue or stop/abort (assuming the same requirement as the OP).
If you have a different requirement, maybe you can describe it in more detail.
GCentral
Message 10 of 12
(3,004 Views)
