project with packed library is loading slower
I've replaced few labview libraries with packed libraries and now project is loading considerably slower. Is this behaviour expected? I am worried that when my project will grow bigger it will took a lot of time to load.
Andrej
(2,775 Views)
Hi Andrej,
I did not found information about loading time of packed libraries.
I checked these pages:
- PPT: https://forums.ni.com/t5/Nebraska-LabVIEW-User-Community/Packed-Libraries-ppt-and-example-code/td-p/...
- LabVIEW Help: https://www.ni.com/docs/en-US/bundle/labview/page/using-packed-project-libraries-in-labview-projects...
I think it should be loaded faster or in the same time, because it is pre-built package. But this is my opinion.
How big is you project?
I suggest you to split up your lvlibp into smaller packages. If you have host-pc VIs and remote device VIs (like cRIO Real-Time) you should put the into separete packed libraries.
The packed libraries have a lot of advantages and benefits in big project, so you shouldn't be worried about difficulties. But it is again my opinion, I have never tested it in big projects.
Peter
Peter Vago
(2,722 Views)
my project is not huge (~400 VIs).
I was hoping too that loading would be faster, but it is completely opposite in my case. And even switching between front panel and block diagram take 1-2 sec. But if I replace packed library with normal library, everything works as smooth.
Andrej
(2,715 Views)
Hi Andrej,
Could you send us the project? I can do some testing on it.
If you want to send it, please do not attach it on the forum but send it to techsupport@ni.com and put this to the subject:  (Reference#1051612)
Peter
Peter Vago
(2,694 Views)
Hi Andrej,
Did you manage to impove the perfromance? Have you sent your project to techsupport?
Peter
Peter Vago
(2,667 Views)
