programming
1. I want to set my knob or dial to increase voltage automaticaly, meaning my knob my increase at a constant speed while doing so, increase my voltage from my DC source (NI PXI 4110). my DC voltage is going to the realy under test.
2. i am using a multimeter (NI PXi 4072) to measure as the relay makes contact, i want to measeure how fast they make contact
3. measeure the contact resistance
4. Display the measured values on a table
How do i do that!
i am fearly new on LabView
(2,781 Views)
simple......
Make use of the timeout case in the event structure to vary the voltage of the knob which will then go to the hardware.
Use local variable to update the knob.
In the same event or a different event populate the read values from the hardware and put the same in a table...
I would love to give out solution.But i guess its a HOMEWORK so all the best...
Guru
Regards
Guru (CLA)
(2,757 Views)
