programming vavle sequence
I am trying to do somehting which I thought would be very simple, but I can't seem figure out how to do this: I want to control a number a valves using predefined sequences, but with some timings in those sequences controlled by inputs from the front panel. For now I am using the USB-6009 digital outs to turn a series of reed relays on/off which in turn control my valves. I want something like a sequence consisting of 5 valves states (e.g. A-E), with each state defined as 8 valves open or closed. My sequence will look something like:
(A(x seconds), B(y seconds) ) z times, C(5 seconds), D(10 seconds), E = final state
The parameters x,y & z will be entered form the front panel.
During the sequence I will also be collecting data from the analogue inputs.
Is my question understandable?
Can someone direct to resources (tutorials, etc.) that will help me do this?
I have already downloaded some VI's which are allowing to collect data and control valves states manually, but it is not clear to me how to get what I need quickly.
Thank you for your help
(2,683 Views)
Look at the many examples which come with LabVIEW and many postings on the Forum about "State Machines."
Lynn
(2,682 Views)
