programming paradigm for ``bit banging''?
Suppose I want to send a clocked data signal out on a pair of digital lines via Labview+LINX+Arduino (or Labview+USB-6008).  What's the "best" way to write out a synchronized signal from a vi?  Right now, the easiest tool seems like a flat sequence (movie) structure, with one frame per clock cycle.  Since I'm just twiddling a pair of bits, is there a text-base way to propagate the signal (ie, via formula or mathscript node?)
If you'd like a concrete application - lets say I want to drive an i2c protocol for a 16bit ADC, and for the sake of learning I don't want to use the canned i2c module in LINX.
Yes, I realize that LINX+Arduino isn't reliable for waits of less than 15ms! I'm mostly just trying to figure out what the best way to write out adigital signal.
Nathan
(3,800 Views)
If you want to set bits from text, you might want to switch to a text-based language. In LabVIEW, I would do this using a state machine - a while loop, containing a case structure, with a shift register around the while loop that stores the current/next state. Alternatively, if you can precompute the series of bits to be sent, you could store them in an array, then use a for loop to write them out one at a time with a fixed delay for every loop iteration.
(3,782 Views)
If you want to do I2C you need digital lines that can tristate.
The best way to go about this that I know is either:
-8452: https://www.ni.com/en-us/shop/model/usb-8452.html
-LabVIEW FPGA: https://forums.ni.com/t5/Examples-and-IP-for-Software/I2C-IP/ta-p/3491271
-HSDIO Card
The biggest issue you're going to have is that standard DAQ cards either can't tristate their digital lines, or can't tristate them fast enough.
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(3,763 Views)
You also don't have a clock with the 6008. It is strictly software timed.
While better than a stacked sequence, the flat sequence structure is of little utility here. Dataflow will control execution order.
(3,743 Views)
I believe the term "bit banging" implies a software timed system. Sometimes it's good enough.
(3,689 Views)
I also suggest the state machine.  Avoid "movie frames" by using more scalable designs.
(3,656 Views)
