programming a 9853 application with labview 7.1
    Hi, I'm fairly new to the compactRIO and I'm trying to program a simple CAN application that sends continuous messages from CAN0 on the 9853 to CAN1 and an external CAN device, and display the readings on a graph. Do I need an FPGA vi to access the CAN module or can I do it just using the RT target? Please help.
(2,740 Views)
Yes, you need an FPGA VI to acess the CAN ports of othe 9853 module. I suggest you look to the NI 9853 examples and the module's documentation in the LV Help for more information on how to use the module.
Hope this helps.
JMota
(2,723 Views)
