programmaticly change cluster size
I'm i'm facing the following problem, i want to display several plots in a chart, to do this i'm using a build to cluster function, because the source is an array with N items. The sollution i came up to, was not correct because the cluster has a fixed size and the array doesn't. Which results in 9 plots (default cluster size) and only N of them have to be displayed in the chart.
I included a part of my program. By which i hope it explains my problem a bit more. This subvi is executed X times and saves N value's to an array and after each run the array is converted into a cluster and is displayed in a chart.
So my question is, is it possible to programmatically change the cluster size, or is it possible to realise a chart which is updated during runtime with new value's.
(2,579 Views)
I figured it out by myself, havn't slept to mutch last night 😉 For those who are interested in my solution, here is what i did after the array is coming out from the forloop i reshaped it so that the dementions are the same as the number of plots i want to have, then i wired the output to a chart and it works
(2,570 Views)
