11-10-2010 06:11 AM
ok sorry. but now i have one more issue. how do i pass the control from the event structure to a case statement in the same loop??? see example.
11-10-2010 06:14 AM
Its simple.Take event on that control as well.
Place case structure inside it. Do not forget to connect Shift register from left tunnel to right In that event case.![]()
11-10-2010 06:19 AM
hmm. ok. the reason i asked is that i already have an existing program with several case statements inside a while loop, and then i was going to add this. but yes, you're right, this is probably the approach i should follow.
