programmatically set frontpanel colour
Is there any way by which i can set the front panel colour. I want to do it programmatically in a lot of sub-vi's.
Pavitra
(3,732 Views)
There is a pane property Pane Color Property to change the background color of a pane.
Ton
My LabVIEW Ideas
(3,727 Views)
Hi Ton,
I tried using this property. It is giving me an error.
Pavitra
(3,721 Views)
Accepted by topic author pavitrabaxi
Just in case you're struggling to find it.
This code gives me a dirty blue color on the front panel...
(3,719 Views)
What error is returned?
And could you show a piece of code
Ton
My LabVIEW Ideas
(3,716 Views)
Thanks Nitin!!
Thanks Ton...
I had not wired the property nodes correctly. Hence I was getting an error.
Thanks again, both of you!
Pavitra
(3,709 Views)
