programmatically resize window
I am trying to programmatically resize my front panel when the user presses a button.  I'm running LabView 8.   Is there something like a property node that can change the size of the currently running VI?  Thanks in advance for any responses.
(3,698 Views)
Yes.  First of all, you can get the current desktop dispay size by accessing the App Property node and select Disp.Workspace for dimensions.  You may or may not need that for your purposes.
But to resize the window, use the VI property node of the window you want to resize, and write to Front Panel Window.Panel Bounds.
Hope this helps
(3,694 Views)
