programmatically publish vi (Web Server)
I want to programmatically publish a VI using the LabView web server.
I already know howto to start and stop the webserver, I just don’t know how to create the XXX.html file, again in a programmatically way.
Does anyone have an idea?
Thanks.
Message Edited by Tonitos on 04-26-2008 05:45 PM
(4,230 Views)
I don't understand your question.  What problem are you having?
Have you used the Web Publishing Tool ....  menu option under the tools menu?  It creates the HTML for you.
(4,216 Views)
I already know how to publish the VI using the tools menu.
What I want to do now, is to publish the VI, using another VI.
Let’s see, if I can better explain my self, I want to create a VI, that is capable or publishing another VI.
For example:
The first VI will be in the server, and, on demand will publish the VI that a client may have requested.
(4,197 Views)
Accepted by topic author Tonitos
Solved.
(3,994 Views)
Tonitos wrote:
Solved.
Then please post some more information on how you solved your problem so other people searching the forum with the same question can learn from your experience.
(3,991 Views)
