programmatically changed attributes do not change in MAX?
I have a program where im using IMAQdx to enumerate attributes (which sets attibutes in MAX) and then IMAQ to grab and snap. Everything seems to be working fine but when I open MAX after playing with the attributes they are not there. The change that i make in the program doesnt display in MAX. IE. I changed FPS to 30 and it got updated in Labview (camera was running at 30fps) but then I opened NI MAX and it wasnt updated there.
any ideas?
thanks
(2,332 Views)
The changes that you make to the camera attributes programmatically are not permanent changes that would show up in MAX. Once the references to the camera are closed in LabVIEW, the settings revert to the defaults in the camera file which is read by MAX.
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(2,299 Views)
