program that work in PXI platform doesn't work in PCI
You said you are changing from P III to P4. Have you hyperthreading enabled? This could cause a problem. With the upcomming P4 NI states that LV is not save on hyperthreaded or multi processor boards. I'm not sure if this was solved with LV 7.0 and NI-DAQ 7.0 or with LV 7.1 and NI-DAQ 7.1.
You can try to disable hyperthreading in the BIOS so your P4 will act as a single processor machine.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 11 of 11
(363 Views)
