program runs in strang way
I have this program running in strang way.
The program is trying to choose one column in listbox by either up down keybroad or mouse click. Then the program suppose to find the corresponding element in an 1D array. Once find it, show the index of the element in 1D array.
The strang thing is: click one column, the highlight column is jumping back and furth or delayed some time to move to the new selected column. It seems there is something wrong in loop.
Please help
(2,992 Views)
Sorry
The old attacment has no data when open it. Here is one with data
(2,974 Views)
Could you put some reasonable default data into the array controls on the left so we can actually test. Then save it as development distribution so the missing subVI is also included in the llb.
So far, the VI does not make a lot of sense to me. Seems quite convoluted. Why do you have a delay in the FOR loop?
(2,973 Views)
sorry my brain is dead really .
I forgot the subvi.
Here is my vis.
(2,967 Views)
please see my last post above yours
(2,966 Views)
You are really an expert. I put a 50 ms delay in for loop, it works.
(2,966 Views)
NO! That's NOT the solution!
You are creating a race condition by reading and writing value properties without need in the same node.
Suggestions (See attached, LabVIEW 7.1):
  • You only need to write the listbox content once outside the loop. It can never change during th run!
  • Use an event structure. The loop only needs to execute if the list selection changes.
  • You can use autoindexing for array2.
(sorry, I took the subVIs out so I can run it, just put them back in). See if this is clear! 🙂
(2,957 Views)
