program datasocket in c#
I am trying to read data from ni datasocket. I want to write in c#.net, or in C++. I have a LabView installed on the computer.
Do you any sample code showing how to connect to the datasocket and reads data from datasocket in c# or c++?
(6,152 Views)
Hi Harry,
              For a reference you can go through my own thread
              Recently through socket programming I can successfully sent data from labview to C# and from C# to labview.The above included thread helped me a lot.
Thanks as kudos only:)
(6,141 Views)
Hi
I am also wandering how to read data from NI datasocket in C#. Do you found any reference / Code snippet? It would be really helpful, if you give me some hints.
Thanks & Regards,
Shree
(4,843 Views)
Hi Shree,
I found this example for you which does have some age on it but it may still be helpful.  Were you able to look through the code snippets the user above posted in his thread?
DillonL.
(4,833 Views)
