producer consumer troubles
Could you reattach your VI''s in 2012. for some reason the lib you've attached is corrupted and labview can't open it.
Dan,
Message 11 of 12
(391 Views)
Hi Charles.
Another possible method for solving your problem might be orienting your solution to be a state machine that uses event structures. This type of solution is pretty efficient for the problem you have. You can formulate your problem like a flowchart and then get going on the programming part. I found some whitepapers at ni.com that might come in handy for you.
Using a State Machine (Event Driven) Architecture
http://www.ni.com/white-paper/2926/en/
Tutorial: State Machines
http://www.ni.com/white-paper/7595/en/
Exercise: State Machines
http://www.ni.com/white-paper/7604/en/
Application Design Patterns: State Machines
http://www.ni.com/white-paper/3024/en/
Module 7: State Machines
http://www.ni.com/white-paper/7532/en/
And an example of a VI with a GUI that uses a event structure driven state machine.
State Machine with UI and User Event structures
http://www.ni.com/example/27941/en/
Hope you find all that information useful.
Fabian.
Fabián M.
Internal Sales Engineer
Message 12 of 12
(357 Views)
