04-20-2015 07:31 PM
I do File > New... > VI > From Template > Frameworks > Design Patterns > Producer/Consumer Design Pattern (Events)
Then without doing anything to the block diagram or front panel, I click on the "clean up diagram" which does the auto block diagram cleanup. Bam! Consumer loop is put on top of Producer.
I tried a bunch of combinations of the Block Diagram options settings (wire spacing, move controls left, etc.) , but the "clean up diagram" always wants to put consumer loop on top of the producer loop. How can I get labview to maintain the original loop positions?
04-20-2015 07:42 PM
04-20-2015 08:26 PM
There is a reason a lot of use do not like to use the Block Diagram Cleanup. It generally works for simple VIs. But I would not use it on my top level architecture.
