producer consumer loop array building
I am trying to build an array in the consumer loop of a queued vi. This is the first time I have tried to use a producer-consumer structure since class many months ago. Each element is queued and sent to the consumer loop, and in that loop I want to build an array of the elements before I save it to disk. For some unknown reason I am having trouble accomplishing this. Usually I throw this stuff into a for loop, but here it isn't working.
I am converting the random number to a string in the producer loop because when I build the real program I will be using strings.
What am I missing?
Tay
(3,089 Views)
Just built your array in a shift register.
(The error case is simply wired across.)
Message Edited by altenbach on 05-16-2008 08:03 PM
(3,084 Views)
I'll have to try that; I didn't think of using the outer while loop; I wasn't thinking that it would stop and wait for the next queue; I'm still used to those things just running all the time!
Thanks!
By the way, I have a work computer that doesn't display the rate answers feature; how do I turn that on? I'm using Internet Exploder.
Tay
(3,080 Views)
It should show since you now have over 50 posts.... just wait a bit.
(3,075 Views)
That worked a treat!
Thanks!
TaySmiley Very Happy
(3,074 Views)
