problems with labview and opc
I'm using the eval version of Labview 8.5 and I'm trying to connect Labview to a Kepware OPC server. I found a tutorial about how to do it but when I follow the instructions I don't have the option to add an "I/O Server" for then select the OPC server. I want to know if that's because of the eval software and I have to buy it or there's another way to connect Labview to the OPC. I have my PLC Siemens connected to the OPC but not the OPC with Labview.
Thanx for your help
Message 1 of 10
(4,689 Views)
          Well I never had the eval version but I guess this option should be on it. You have to right clic on "my computer"in your project, and select "New -->  I/O Server", If it really doesn't appears then you can try to use data binding in a control (right clic in a control or terminal of the same data type of the variable you want to connect to: Properties/ Data binding/Data socket/DSTP server/select your OPC server/select your variable or address)
Paul
Mechatronic engineer
Lima-Perú
Message 2 of 10
(4,678 Views)
When you right-click on My Computer>New there doesn´t appear the I/O Server option or it appears but when you click it, the I/O server list appears empty?
The I/O servers appears only if you have the DSC Module Installed. If you don't have it, the I/O servers list appear empty.
JCFC
Message 3 of 10
(4,614 Views)
Maiki,
The evaluation version os LabView does not offer the possibility of using any I/O or external hardware.
Dario Camargo
NI Brazil
Message 4 of 10
(4,523 Views)
Hi Maiki or somebody else
I have exactly the same goal. How do I use kepware with labview. I saw your information that, you had an torturioal about how to use Kepware OPC with Labview., Can you pls. send me a link, or tell how to find that torturioal.
Dears Lars
Message 5 of 10
(4,485 Views)
Hi Maiki,
        Paul_m is dead right !! Follow the instructions as given by him . (Right click=> Properties=> Data Binding =>Browse(DSTP Server) =>KepwareEX OPC server => Variable name)
        I have used this method successfully.
        Shaheryar
  Electronics Engineer
Message 6 of 10
(4,477 Views)
Hi LBD,
As far as I know you need the DSC Module or the DSC Runtime to use the Kepware OPC-Server. When using Shared Variables it is very important to run the Kepware OPC-Server as a service. If you have further questions, please ask. Notice that the OPC-Server in evaluation mode is only free for 2 hours.
HTH
Joachim
Message Edited by Joachim082 on 04-20-2008 07:55 PM
Message 7 of 10
(4,468 Views)
Hi
I've done with Data Biding and is working perfectly.
Thanks a lot,
Maiki
Message 8 of 10
(4,444 Views)
I am having the same problem of coneecting with the Kepware OPC.. I dont have the DSC module but i still want to connect.. I tried out the rightclick of the My computer in my new project and clicked on the properties menu.. But I dont see any data sockets. All i see are:
General :
Vi server : config
Vi server : machine access
Vi server : User access
Conditional disable Symbols
Math script : search parts
 i have a full development version of labview.. could any one suggest on it..
Message 9 of 10
(4,259 Views)
Never mind.. I figured it out.. My bad.. But the data binding works awesome...
Message 10 of 10
(4,254 Views)
